how to set the size correctly with data archive on wincc flexible 2008
JEANST
Jun 2015
PARIS
68
Hello
i have currently a problem
with data archive that are used to display on trends
i have approximately 50 tags recording with an update rate of 10s.
the Customer wants to have a recording on the last 24hsours max on the trends.
I encounter the following problem, it works fine and after a couple of hour the recording stops and then nothing more appears on the trends.
I have tried several cards to record. CF card USB key MMC card... always the same problem. works ok then stop recording..
I Wonder if the number of records is not too small.?
if someone knows this problem..
Thanks in advance
29-06-2017 15-05-53.jpg 29-06-2017 15-06-50.png 29-06-2017 15-07-32.png 29-06-2017 15-07-44.png 29-06-2017 15-08-55.jpg
Is there anyway to dynamically alter the size of a data block? I'm developing sofware to simulate a 'Last In First Out' structure using a data...
1,787
Hello, I still do not have equipment in to test. But the RTAC ladder does not have a timer reset coil. I wonder if a reset coil on Timer.IN is...
128
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
63
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
405
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
120
