Calculating Fluid production with Submersible pressure sensor
damica1
Aug 2015
Illinois
839
Hello:
We use submersible pressure sensor in oil tanks to monitor the level in the tank.
We also have a routine the will estimate the oil production, buts it's not very accurate.
I would like to hear anyone else's ideas on how they might approach this, I would like to be a little more accurate.
If the tank is pressurized at all the drop in sensor won't work.
The Wet oil tank at my previous job had a thief hatch but it held at 8 oz. that 8 oz will throw off a drop in.
The best method for level that I've seen is a radar or A differential pressure off a sight glass mount.
These tanks are vented to the outside so they are not pressurized!
I have used these for years, and they always show consistent reading to the 1/2 inch.
I am needing some type of formula that can be applied to show production.
Something like what I am doing now but maybe be a little more precise.
I read the tank level every 15 minutes and subtract the difference from the last tank read.
I disregard any negative as that is probably a tank being emptied.
Would like some new(better) ideas.
Does it happen that the tank is being emptied partly during production?
How do you want to present the production? In volume or volume/time?
"subtract the difference from the last tank read" isn't the produced amount = actual level - level earlier?
When you say Oil are you talking about Crude Oil? Are you trying to do some type of Custody Transfer with your set up?
This application has a motor with encoder feedback that drives a linear actuator that moves in/out, and is at roughly 45 degs from horiz. As the...
19
1,365
I need to keep a running pass/fail yield of the previous 5,000 parts produced. I have used this formula before to calculate average: AvgValue =...
2,156
Does anyone know how to calculate the savings from now needing to run an air compressor all day? Basically I have a design that replaced 6 * 1"...
26
4,828
I would like to refer to this document of which I used some data ...
1,478
Seems like this should be a simple thing but I’m struggling with it. The basis is that I am trying to detect if a linear assembly is stopped or...
3,098
