AB SLC 5/04 with Redlion for DAQ
harigb
Jul 2019
Hi
I am having AB SLC 5/04 PLC with supported DF1 protocol from RS232 port.
But I'll explain my challenging situations, In our production line we are using two SLC 5/04 PLC. Both are communicating with AB DH+ protocol. In that two PLC's there's RS232 Port available, One with DF1 Half-Duplex slave protocol configured and other with DF1 Full-Duplex configured.(Here we know RS232 serial port configurations for those PLC's, and the challenge is we are not allowed to change it). Both PLC's are placed in different panels, and both are at ~100 mts distance. We can place to accommodate Redlion product in one panel where PLC with RS232 DF1 full-duplex configuration. With these existing configuration and challenges, We wanted to understand the following.
  1. 1. Does Redlion DA30D works with the SLC 5/04 PLC for DF1 Half-Duplex slave and DF1 Full-Duplex.
  2. 2.If it is going to work, I can connect one PLC directly with in the same panel, where other PLC need to travel 100 meters with RS232 DF1 configuration, which is not possible for serial communication. So, I wanted to know if I convert that PLC RS232 to RS422 at the same DF1 Half-Duplex slave does this works for DAQ with both SLC 5/04 and Redlion setup
Newbie here, so apologies in advance. In short, we are using a Redlion DA30D to read/write values from an Allen Bradley SLC 5/04. Communications...
1,427
Hello, I'm taking in two 16 bit ints from the field via modbus, one low order and one high order to combine into their proper 32-bit form. I've...
1,280
I Have an SLC 5/05 in the office configured as a Modbus RTU Master reading and writing data quite happily to and from 2 weight dosing terminals...
2,776
I'll try to simplify this as much as possible... I have a G308 that acts as a webserver dashboard and collects misc data (bottle counts, bottles...
18
4,021
I have a G306 hmi I have tried to upgrade from a panelview 600 on an existing line that is connected to a SLC 5/03. I have had succuess for the...
2,587
