Help me about Flow Meter
PLC_Primer
Guest
P
Hello All,
I am now in the task that to design a dosing system.
i am looking for a cheap flow meter with pulse output, may be 10 or 100 pulses/litre. I will push this pulse to input of Siemens PLC CPU222, then i use a counter to calculate the mass of flow.
Could you help me what brand of flow meter i should use ? as cheap as possible ! (i use 0.75 KW pump)
I am looking for your helps.
Thanks.
Hello,
We need additional info to solve your problem. What kind of product or you willing to measure, what or the piping dimensions. Can we use flans or clap coupling ect.
In what kind of environment is the equipment going to work. What's the wanted accurency?
Rudi
Hi !
Hi Fritz_frederix,
Do you know SIKA ? it is a material using at beton mixing station, to keep beton not to dry. i use the flow meter to measure the flow of SIKA and display at the panel.
The high accuracy is not neccessary in this application, the diameter of connection is about 3/4".
you could suggest me which manufacture can supply, i will contact them for detail(about connection, diameter).
http://www.gfsignet.com/
I use these to monitor all my water applications
4-20ma - Pulse
Many differant applications and size. Very accurate
Hello guys, I need some help. I read all the old posts on hall effect sensors but none dealt with my module. The system uses a Gemco 194761 RFO...
1,721
Hey guys, I have MLX LOGIX1400 running fine except that it faults sometimes on math over flow. I examined the program and spotted a...
2,324
So I have an ABB TotalFlow uFlo G4 unit and have configured it's COMM port as Modbus Slave. I have also mapped internal 32Bit Float Registers to...
5,824
Hello all, I've got to make a totalizer for our digester acid fill using rslogix 5. I have a flow transmitter scaled for 0-16000 LPM using a CPT...
5,170
I have a ABB Totalflow 6213. is anyone here knows how to change the display to show from PSIA to PSIG ?
1,334
