Codesys TON Extension, doesn't run
theColonel26
Feb 2014
West Michigan
785
Using Codesys 3.5 SP15
So I extended the standard TON function block as follows
http://www.plctalk.net/qanda/attachment.php?attachmentid=52942&stc=1&d=1577037174
The problem it doesn't run and I am really confused as to why
And then I create a wrapper around TON instead, like this
http://www.plctalk.net/qanda/attachment.php?attachmentid=52943&stc=1&d=1577037174
and the wrapper works fine
here is a video of them both "running" side by side
https://drive.google.com/open?id=1hHS4xCB1wGKL1ibBhoxLEW3mw3hFIJGd
You replaced the function block call without calling the original function block.
In ST, you would add this line to your extended function block:
SUPER^();
Maybe in ladder you either insert an execute block and call SUPER^(); or insert a block with EN/ENO for SUPER^?
SUPER^();
:geek: Thank you I didn't know I needed to call the base FB.
I created a BOX call and set the type to SUPER^
More Codesys questions coming. I am loving it so far. RS 5000 is icky.
I used Codesys 2.3 Years ago and liked it. Haven't had an opportunity to use 3.5 until now.
Does anyone know of a library that already has a implemented RTO? I was going to write my own but I'd rather not take the time.
35
11,330
Hi there, We have a German machine with an Eaton XC-202 plc. I purchased the X-soft CoDeSys software and XT-SUB-D/RJ45 cable for programming...
4,066
Hi, I am learning CoDeSys and my first attempt is to program a simple or statement to turn on an output using ladder diagram. I have completed...
13,325
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
294
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
90
