SLC500 - Adding Message Data Type
Ones_Zeros
Feb 2014
at work
367
Hello
I was trying to add a "Message" data file in a SLC500 PLC controller.
I'm not seeing the Message as a "type" to select.
How do I add the message as a option to choose in the type box from with the "create data file" dialog box?
thanks,
MG datatypes are only for the MicroLogix controllers.
In any SLC-500, use a block of Integer (N) data of the appropriate size. DF1 or DH485 or DH+ messages use 14 words, and Ethernet messages use 51 words.
So I would use these instructions? (DF1 or DH485 or DH+)
I’ll do some research on how to use them to message
between SLC500.
I’m not sure how to use them
Could you possibly provide an example?
Thanks for the explanation
I appreciate it
Which exact models of controllers are you using ? What sort of network connections do you have ?
What's your goal for messaging between controllers ?
Ken
Thanks for helping.
- The model of both PLC controllers is 1747-L552 (5/05)
- The network connection between these two PLC’s is Ethernet CAT5 connection.
- My end goal is to Message over several (N) Integers from PLC A to PLC B.
I will be using these Integers from PLC A to turn on a Output in PLC B
Thanks Again
Hi All: What is involved in adding a new AO card to a SLC500? From what I understand, hot swapping is not an option. So I my guess (and Im...
3,034
I have a slc500 plc 1747-L30A. Using a communication cable 1747-PIC cable box combination. Running a version of software from DOS on a Windows 3.1...
176
301
can the slc500 5/05 send a email and text over Ethernet ?
203
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
403
