Communication between Unity Simulator and Citect 2018
Mar 2016
PERTH
The simulator panel shows the Scada is connected. However, the pages don't read any tags at all. The PLC and Scada are taken from the live system for development purposes and were obviously connecting. Could only attach 5 images although had more images to show the configs.
Have you got the Citect system and the simulator running on the same machine?
The Unity simulator will not simulate real world communications, the Citect system will need to be on he same PC and use 127.0.0.1 as its device communication IP.
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
25
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
85
109
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
115
Or there is an alternative to this? I suppose there are many but I've only seen put/get Can you for example set up a new plc and connect it to an...
305
