FTV SE Object Property and Arrays
JGax
Nov 2013
Mexicali
28
Hi
Hope you all are doing well!
Im a fan of this forum, basically read and learn.
Today I have to ask for your help...
Let say Im developing a HMI, which will display 100 objects, each object will link its properties, like visibility, color, etc, to an array in PLC....
Object1 to array[0], object2 to array[1], and so on....
I can link the very first 10 objects to its respective array[x] easily but im thinking that I have to do the same to about 1000 objects......
Is there a way I create a Object and the copy and paste with it respective array[x] to the next array index?
Hope I explain well, English is not my first language.....
I really appreciate all your support....
Regards
Jesus
The easiest method I can think of would be to do it with your first 10 objects, then export the display to XML, and use Notepad++ or another XML editor to copy and paste and increment in there. Then re-import the display
Thanks for your reply....
I will try for the next 100 elements....
For my first 100 I create a group of objects referenced to the array element....
Then copy and paste, select the pasted group and right click select tag substitution and there replace the index only.....
That works for a few groups.... 100s is really tired
Appreciated your comments
Hello, I'm having an issue that I did not expect to run into. Using FTV SE v11.0 (CPR 9 SR11) I've created and saved a global object inside the...
1,542
Hello, I have a global object for a button set up with two parameters. One that is the "control tag" for the button and the other that is the...
2,216
Hi, I'm currently developing an HMI on FactoryTalk View Studio v12. It seems that global object instances will randomly lose their link to the...
2,042
I have a bunch of devices on my displays that are the same. I have build a global object for them and is working great. I want to place a button...
1,966
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
152
