The timer doesn't work when it is triggured
michonezol
Feb 2020
Netherlands
Hi everyone, I am a newbie in PLC programming.
This is my code written in ST
PROGRAM MAIN
VAR
Motor :BOOL;
Start :BOOL;
Delay :TON;
button :R_TRIG;
END_VAR
button(CLK:= Start);
Delay(IN := button.Q, PT := T#5S, Q => Motor);
The idea is simple. After 5 seconds the button is pressed, the motor will work.
But, the program doesn't work as expected. I don't understand why
Could you help me out please?
Thanks so much.
Not sure of the platform, but -
If Start is TRUE but the next line shows In FALSE it may be the syntax of Button in the 2 lines
First line = button(CLK... on the second = button.Q, maybe it is looking at a different value.
TON timers usually require the signal to be high... not be a pulse.
Perhaps if you have a pulse in the button you latch a bit that will keep the timer counting?
Welcome to forum
It is lot of easier start with ladder or function blocks programming than ST.
On program is couple issues.
TP (Timer pulse) makes pulse to ouput as soon there rising edge on input. it won't delay output. (pulse 5s now)
you have rising edge detection of button. Q is on "1" only one program cycle, so you can't see it on animation view.
What you need now, is TON timer
So you probaly have now 5s pulse on timer output as soon as you pressed button
p.s Forgot, there is TON timer configured on program, looked first that there is TP šŸ™ƒ
You only need to configure button without R_trig
There is R_trig on button configured
Codesys šŸ”Ø
The source of the timer IN (run?) bit is a one-shot that is True/1 for exactly and only one scan, so the timer resets on the next scan.
TL;DR
button is an R_TRIG i.e. a rising edge trigger (one-shot), so button.Q will be True/1 for one scan and then reset to False/0 on the second, next scan.
I don't know what brand of PLC you are using, but I think that for most brands, Delay:TON will reset when its Delay.IN, which is one-shot output button.Q, resets on that second scan after the one-shot fires.
A TON reset means the timer will
  • stop running
  • set Q to False/0
  • reset ET to zero.
In most cases that second scan, when the one-shot output button.Q goes False/0, will occur before the 5s timer expires.
When button.Q goes False/0, the timer will reset and never reach its 5s PT value.
Do you know the solution? Is this a homework problem?
Well, I am trying to learn a PLC program, so I have created many simple problems like turning ON/OFF a lamp, blinking a lamp, or something like that... so there is no real PLC unit involved here.
A platform is Codesys.
My own current problem is: After 5 seconds (or any second) the button is pressed, the motor will work (or turn ON). As simple as that :)
Maybe you are right.
I still don't have a solution yet :D
thinking that on config you need this line
button : Bool;
(same way than you have for motor)
then on st
delay (in =button, PT = t#5s, Q => motor);
And check that you haven't used same timer multiple times on program.
oh man, it works :D
thanks man
Yeah, you had one shot trigger there
TON timer input was on only one program scan (which is something around 1-20ms maybe for default on your PLC configuration)
So your timer started to count, but on online you won't see it as it is so fast.
If you would have TP timer whit one shot, then it would have gived 5s pulse. (and also even with button: bool configuration)
(y)
oh yeah, man, you are right. Sometimes I see the system running pretty fast, so I could not catch each step :D
Thanks for the great responses so far. Where can I go to find the absolute basics? Bit vs byte for an example? Or even microprocessing etc?
Hi, I want to register the time of operation of a valve. I'm using timers to simulate a one second pulse, but the output doesn't activate. I...
1,762
In Mitsubishi's PLCs, there is no off-delay timer. If you need one in your program, how do you get one ? :)
13,319
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
93
Hi all, I have a simple question that I have overcomplicated and gotten stuck on. I have a variable, we can call it "light" that I need to stay...
315
Question to anyone with ideas about my thoughts on upgrading a very vintage timer, which is being used to switch between 2 5hp domestic water...
437
