bright676 Member B Join Date Nov 2012 Location va Posts 494 Nov 14, 2019 #1 On PB32, PV 600 I want to add a screen for a analog tempurature trend. How does the Graphic Indicators-linear set up work? Where do I add the tag to it? I know its outdated, but its what is on the machine. Thanks
nehpets Member Join Date Mar 2009 Location Wales Posts 496 Nov 14, 2019 #2 The linear indicator is purely an overlay you will need to generate a bargraph and use the linear overlay to give you a scale. Steve
bright676 Member OP B Join Date Nov 2012 Location va Posts 494 Nov 14, 2019 #4 Forget it, its not worth the effort, they never had it, wont miss it.
Ken Roach Lifetime Supporting Member + Moderator Join Date Apr 2002 Location Seattle, WA Posts 17,490 Nov 14, 2019 #5 Analog trending was an exciting new feature of the PanelView Plus in 2003 because the PanelView Standard didn't have it. You could roll your own with an array of vertical bar graph objects, but that's the only way.
