I am just exploring the options to replace an outdated filling valve controller for a can filler. It has 78 filling valves and runs at max speed of 300 CPM. Filling mostly 375ml cans by switching 8 solenoid valves based on a 4-20mA level float sensor. The filling happens roughly through 25% of the rotation window. So I have estimated about 4 seconds to fill the can and we have about 10.4 milliseconds per ml.
There is 78 level probes and 624 digital outputs. This has to be an Allen Bradley PLC to control this (site standard). What hardware would you guys suggest I look at?
I was looking at the using control logix and the 1756-IF16 in high speed mode (4 Channel) but it has to be on the local rack and that's about 20 cards just for the level probes. Then another 20 x 32bit output cards for the solenoids. Is there a better way to manage this sort of application?
Thanks,
Thanks,
