Dan123
I have an existing machine running a 1768-L45 CompactLogix and the client wants to add linear actuators (http://www.ealingcatalog.com/motion-control/actuators-adjusters/encoderdriver-actuators.html), but the motion controller that they are using is USB. It has an ASCII command set, and I am able to control and monitor the actuators using a virtual COM port and RealTerm.
My question is -- what is the best way to set up communication between my PLC and this device? If I use a USB to Ethernet gateway, will message instructions work to send/receive commands? Is there a better option out there to communicate between USB and PLC?
