RSLogix Migration tool
dcam
Apr 2012
Merced Ca
161
Im trying to convert a 500 program to control logix. The process keeps stopping because of a destination address in the PID "PD11:0.CVH" It does not like the CVH part. Wish it was easier to post picts, it would make things easier.
So i think CV is control Variable...whats the H? and how do I fix for migration. First cut over by myself.
Control Variable High Limit.........is there a way to call it out differently that the control logix likes?
Since you're using the PD control block, that must be a MicroLogix 1400 program that you're converting.
What version of the Conversion Tool are you using ?
My workaround approach would be to create a dummy integer file and reference that instead of the PD file.
PID is one of the features that needs the most attention to convert from PLC/SLC/MicroLogix to ControlLogix, so you're going to have to put some effort into that part of the program anyhow.
Any reason I would not have the Project Migrator selection for converting from plc 5 to CL? Thanks!
1,195
U
Hello, I was wondering if it is possible to import/migrate an existing RSLogix5 (PLC5/30) application into RSLogix5000 (Controllogix), or do I...
4,053
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
111
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
130
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
210
