Input Device Identifier
alexbeatle
Feb 2010
San Francisco
188
Hello, all!
I have a couple of foolish (no smarts) trailers with conveyors. These are controlled by AB PLC when connected using a connector. Right now there's just a jumper on a pin that links 24vdc to a PLC input to indicate that a trailer is connected.
Given that I cannot expand or change the connector and only 2/3 pins. Could you please recommend some sort of identifying device so that I know which trailer is connected exactly?
My current idea is to replace jumpes with resistors of unique values and read the current/voltage on an AI card...
Thank you.
your idea of using resistors would certainly be the easiest/cheapest idea, but depending on the connection and how clean it is kept, and how many trailers you need to identify, may not be a very reliable method.
Instead of using the plugs, perhaps you could embed an RFID chip in the trailer, and a scanner in the dock. You might even be able to embed the RFID inside the plug for the trailer. You could, of course still use the plug as positive verification that the trailer is in position.
Do you happen to know if there's a wired equivalent?
You can use a programmable relay like this : https://www.ebay.com/itm/Programmab...mer-Relay-Trigger-Switch-Module-/192017554546
Then each of the conveyors should generate a different sequence of on-off pulses, for example with a long pause off state followed by a number of pulses different for each conveyor.
Although one drawback that I see is that the output relay is mechanical, it would be better if it were solid state .... maybe it can be changed
Why not add another connector, use a dummy cable and link the pins in binary i.e. 001 = 1 010 = 2 011 = 3 100 = 4 etc. the cable is just a tie to the trailer.
so that the operator has to plug in the two connectors (make sure they are not interchangeable).
Hello, friends, I am trying to upgrade a system that uses an Onrom incremental encoder (E6B2-CWZ6C) connected to a Danfoss VFD (FC360), but now...
289
I have an application that needs a simple way for an operator to input an integer value and send it to a PLC. An HMI is overkill, but I am...
1,294
Hi; I need to monitor and log the 3phase AC input voltage for which I need a device to convert AC input voltage (say 350 - 440V) to analog (0-10v...
1,384
I'm not sure the best way to do this. I've got an old GE plc with only 120V relay outputs. I'm replacing a UV light component with an LED...
1,900
Ok so here's the poll... We need a standalone device that can send an email or SMS message on an external contact closure. It will connect to...
2,721
