Can't drag faceplate to screen (WinCC Flexible 2007 Standard)
Kaspergl
Jul 2010
Denmark
I have created a faceplate like the example says, but I'm not capable to drag it from my library into my screen. I'm only having the "stop"-sign..
What's wrong?
Hi, do you know how i can add pens in a trend by drag and drop the variables, without using "Add/configuring tags" windows. The Add/configuring...
1,138
Hello Guys, Im having trouble to drag and drop symbols that i imported into symbol factory in factorytalk view? does anybody know why? the format...
1,842
Why is it that I Can't drag Done bits from timer, when I can drag Bit values into an instruction?
2,385
Good evening, I can't drag the rung down around my inputs and outputs for some reason in my PLC program? I can't do it for any programs. I'll...
1,421
Is it possible to use two infrared sensors . One for starting timer and one for stoping timer. result could go on lcd display or sreen. Could...
1,004
