1747-l40b
roxusa
Nov 2008
NJ
994
I'm trying to modify a program in an old 1747-L40B and I see it in RSLinx
but can not upload I get an unknown Decompile Error. I seem to recall years ago
having trouble with this same unit when I was trying to
upload all programs in the plant- I had a sheet with instructions to do something. I think
It had to do with it being loaded with 6200 software. we have multiple
branch lines on a conveyor system with these bricks communicating through a DCM to the main line SN Module, all the others I can go on fine. Does anyone have a suggestion. All the work I've done reconfiguring the line won't work if I cant download the program changes.
Is there any way to force this to Default and load it with a new program
using RS-500, I have tech support but not 24/7. trying to find a tech note in knowledge base. Hope I don't have to pull the unit and stick in an old 502 with a small chassis.
Only using 16 in and 13 out and a DCM all 120 vac
I have an old Fixed I/O controller running a take off line for a machine on the conveyor system. It has a 2 slot expansion unit on it with a DCM...
2,210
Hi I just recently joined a company that uses AB SLC500 1747-L40B plcs. I have noticed that all the plcs have an AB Isloated Link coupler 1747-AIC...
1,688
What is the recommended fuse type and rating for a fully loaded Allen Bradley SLC 1747-L40B with a full 2 slot expansion unit? My manual is...
4,685
Hello, I have a 1747-L40B PLC and a PIC converter. How do I set up RsLinx to communicate with the PLC. I tried to instll the 1747-PIC/AIC+Driver...
2,098
I have a slc500 plc 1747-L30A. Using a communication cable 1747-PIC cable box combination. Running a version of software from DOS on a Windows 3.1...
70
