Fusing for a Allen Bradley SLC 1747-L40B
May 2004
54
What is the recommended fuse type and rating for a fully loaded Allen Bradley SLC 1747-L40B with a full 2 slot expansion unit?
My manual is misplaced and at the moment I can't read pdf files.
Thanks John
I have some output modules wired to IFM modules and I need fuses for the IFM modules. The manual says they use 5x20 fuses so I take that to mean...
2,536
Hi all, I'm working on a safety circuit and had some question about fusing. Incoming supply - 120V/15A Power supply - PSL-24-060...
590
The cards have two internal 3.15A fuses, one for each group, and a 0.5A max current loading per point @ 60°C (140°F). They also have a 5A surge...
1,066
I've just created a small program and saved it. Then I clicked on the 'Download to device' icon and this dialogue box appeared. Do I need to...
20
1,433
Engineers and designers, question. Do you typically fuse the PLC outputs ? I see some that are fused and many that are not. I typically fuse...
1,068
