Indirect Addressing - Crimson 3.1
UKB
Aug 2014
UK
56
Hello,
Im trying to write some values from an array of floats to a file on a CSV card.
If I address the array element explicitly the values are returned. However when I try using a pointer I cant get a valid output .
explicit addressing returns a value from the AsText command
in both attempts below indirect addressing returns 0 to the string tag
thanks
UKB
Case Closed. I had the syntax mixed up. Doh!
Should of been
Array.Counter = i;
thanks
Howdy folks, I am an Allen Bradley guy currently living in an Emerson world. Working with Rx3i on PacSystems Machine Edition v. 9.6? i think...
621
Hello, I'm very new to programming with absolutely zero schooling in this field and pretty hands off training in my new role, it's been fun...
668
Hello Friends, I am trying to index M Bits, however GX Works2 is not allowing it with following message. https://ibb.co/zPcqj6M...
1,380
Hi All, which the best way to do the indirect addressing in an optimize DB? Ccurrently this is my partial code inside an FB...
2,273
Hey everyone, Just used the PLC5/Logix migration utility to convert a program, and while addressing the PCEs, I noticed a lot of errors for "XIC...
1,983
