![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
What are you guys using instead of Kroy shrinktube labels?
Now that Kroy has closed it's factory, What are you using for shrink tube labels?
Looking for the same durability as the Kroy labels had (ie. no smudging). Please state the features you like and dislike if any.
__________________
Vaughn If you can read this, thank a teacher. |
#2 |
![]() ![]() Join Date: Jan 2011
Brady BMP (Don't remember which one) but I think most of them will do many different label medias including heat-shrink. The heat-shrink tubes are "ironed" flat on the label carrier and I find it easiest to pull the label off of the carrier by sticking a small screwdriver into the tube and then pulling of of the carrier.
Cheers Ken |
#3 |
![]() ![]() Join Date: Sep 2015
Are you set on heat shrink? Brady has self laminating labels that work very well.
#4 |
![]() ![]() Join Date: Oct 2007
we use brady wire labels and also automation direct plastic wire numbers that slip on wires.
regards, james |
Bookmarks |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
brady labels | jimcav | LIVE PLC Questions And Answers | 4 | June 26th, 2006 06:38 PM |
I/O Labels | Bob.K | LIVE PLC Questions And Answers | 3 | April 16th, 2006 02:57 AM |
S7 - just for info, curious problem with Labels | RMA | LIVE PLC Questions And Answers | 1 | June 29th, 2005 02:02 PM |
S7 Jump labels | Werner | LIVE PLC Questions And Answers | 12 | June 23rd, 2005 11:21 AM |
Merging labels and ladder on a PLC5 | Philadelphia Frank | LIVE PLC Questions And Answers | 3 | April 30th, 2004 01:04 AM |
