WinCC Flex - Tag Multiplexing - CSV
cjd1965
Apr 2007
UK
1,659
Hi
I have approx 2000 tags I need to use in a mutiplex method. I exported the tag list to csv but the mutiplex tag has no multiplex data associated within the file.
Can I do this in Excel somehow or even a database hack or am i restricted to manually entering the data
Cheers
I am not sure how it can be done directly in Excel or a database. But Multiplex tags in WinCC should show up through an OPC server like any other tag. If your multiplex tags appear in OPC Scout, XLReporter can get data or report automatically/on-demand from all the multiplex tags (including those associated with them). Try our evaluation version from http://www.TheReportCompany.com/product_download.htm. We also have technical note on how to connect to WinC.
Bill
Hi maybe i didnt explain correctly/ well enough.
Say I have 100 pumping stations called station 1...100
Next... Say each puimp station has 100 valves called valve 1..100
I am creating a single HMI page in wincc flex to look at pumping station x and then its valves 1..100
The tags are dynamic within wincc flex.
For StationNameInt Tag Value of
1 - Display would be Station 1 (Scotland)
2 - Display would be Station 2 (Wales)
etc
And valvetag1 value of
1-Scotland.Valve1Status
2-Wales.Valve2Status
etc
I would say that editing within EXCEL from a tag export file is not possible... and based on lack of replies no one has a work around
So hours of typing/clicking awaits me... wondering if my kids need more pocket money for some typing
Cheers
I don't know specifically what you are refering to but I had a OPC or DDE project in Excel about 8 years ago that had thousands of variables and the power of "Find and Replace" was a life saver for me. I coded it so that this method would allow me to whip through it. Still manually done but at 1/8th the time (if I recall it was octal based).
Hi.. forget opc/dde
Within the wincc flex editor i have 2 internal tags, 1 of type string called label, 1 of type int called pointer.
I also have plc tags called 'system 1...100'.
Multiplexing will let me do this within the wincc editor
If pointer=1 then Label= system1
If pointer=2 then Label= system2
ETC
When I export the tag database to excel the multiplexing is not included
As said before I dont think this is possible
There are some methods for searching and replacing within WinCC Flex, and copy with regular copy and flat copy.
You may have to experiment with it to find the proper procedure. But could be a way to do it.
Hi All, I have some WinCC flex templates that I need to duplicate in the same project but for a different connection (PLC). I cannot find any...
4,476
I am a little confused by a program that I am looking at. So If I got this correct multiplexing is using indirect addressing (Which points to an...
3,884
In Flex sp2 in faceplate editor, I want to make a button visible when a external tag from plc (mw100) has value 4. In the designer, I can only...
5,246
I'm programming an MP370 (for the first time) and using WinCC Flex 2008 advanced. Please excuse my ignorance because I'm used to AB PanelView +...
4,449
  • Poll
Can anyone help. I am a novice user of WinCC Flex. I have a project that i just want to log 60 Tag values into a CSV file once an hour. I...
5,768
