Connecting to Mitsubishi FX-MR48 PLC using GX Developer
jejump
Apr 2018
Nashville, TN
Hi all,
I tried to connect to a FX-48MR PLC for more than an hour last night with no success. Can someone tell me where the "FX" option is in PLC TYPE? All I see there is FX0 to FX3 and variations within. There is no straight up "FX" type in my version of GX Developer. Also, I found some evidence that the DB25 serial connection might be RS-422. Is this true? I was attempting RS-232.
Thanks for your attention to my issue!
John
Oh yeah...
GX Developer v8.?.?
Windows XP laptop
Native Serial Port
DB25 to DB9 Null Modem Cable
The DB-25 FX port is RS-422, You need the SC-09 cable that has a 232 to 422 converter inside
Thank you to all that replied, and thanks for clearing up the cable interface for me.
About the PLC type, I get that 'FX' on the front of the PLC is a generic naming of the PLC. When I look at the specific number on the right side of the unit, it still begins with FX-MR48 (FX-48MR-ES/UL) and that type is not in the drop-down list in GX developer. I wish I had the exact version of GX developer for you. All I know for sure right now is that it's v8.something.
Can anyone else relate to this?
Thanks again,
John
UPDATE** I think Ronnie Sullivan answered this already (perhaps). I initially thought in his sentence "And select the FXU/FX2C option for that model" that he was still referring to the cable. I will try this after I get the cable made.
Thanks again everyone!!
John
The numbers and letters after the FX on the plc refer to type.
48 is the total number of inputs and outputs
MR is relay output
The rest is European model and voltage.
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
89
I am trying to get a Mitsubishi GT2715 HMI to read and write from a Eurotherm 3508 controller using 4 Wire RS485 Mobus RTU communications. The...
1,309
We've got a portable cooling pump which circulates a coolant oil. The spec says it can be remotely operated (coolant START/STOP), via a 3-pin...
1,483
Hi, Correction: title should say GTDesigner3 (not softGOT) I've updated some GUI pages using GT designer3 and I'm at the point where I want to...
2,669
I am trying to connect a Allen Bradley CompactLogix to a Mitsubishi FX3U plc using DSPSX unit. I have the CompactLogix working fine but the FX is...
36
7,986
