cornfieldeng
I am trying to get a Mitsubishi GT2715 HMI to read and write from a Eurotherm 3508 controller using 4 Wire RS485 Mobus RTU communications.
The Eurotherm has been ordered with a 4 Wire RS485 card and is set to Modbus communications, 9600bps, address 1.
The HMI is configured with the internal RS422/485 port as Modbus master with 9600bps, 8 data bit, 1 stop bit, no parity.
I have manufactured a short cable that is connected as follows;
HMI Eurotherm
Pin 1 - SDA HB - Rx+
Pin 2 - RDA HE - Tx+
Pin 5 - SG HD - Common
Pin 6 - SDB HC - Rx-
Pin 7 - RDB HF - Tx-
Pin 3 - RSA Linked to
Pin 4 - CSA
Pin 8 - RSB Linked to
Pin 9 - CSB
The above pinout is from the Mitsubishi Connection Manual (GOT2000-CON4-SW1-E) page 4-6, (3) RS-422/485 cable 2 (2 Pair wiring) and the Eurotherm Manual (HA027988) page 27, Figure 1-8: EIA232 and EIA485 Connections, EIA485 5-Wire Connections.
I have created a basic HMI application with a single output field looking at the actual values from the Eurotherm, which is address 400002.
When I power it up the HMI reports a communication error and the value is not displayed on the screen.
Any assistance is much appreciated.
HMI Eurotherm
Pin 4 - CSA
Pin 9 - CSB
