plc-learner
I just started learning about PLC's and getting confused about the XIC and XIO instructions. Can someone please answer this question?
An NO limit switch is to be programmed to control a solenoid. What determines whether an Examine if Closed or Examine if Open contact instruction is used?
Is this a right answer?
It depends on whether you want to turn on or off the solenoid.
So if i the program wants to turn on the solenoid, you should a XIC or XIO function?
