Connecting Allen Bradley Micrologix 1200 to RPi via Rs485
jayeshpitale
Nov 2022
India
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED i don't know whether the device is communicating with RPi or not i surf the web for this and i got some point about modbus and all i tried to see whether i can use modbus but i don't know which address has to put and how to read data from PLC.
Hi Jayeshpitale! Welcome to the forums!
I have followed the guide at https://theautomationblog.com/getting-a-b-plc-data-into-a-raspberry-pi/ a time or two for testing with RPi but never in a permanent environment. The viability of RPi in an industrial setting is still up for debate. But I digress.
The 1200 series is an oddball with the release date and version making a difference in the comms options.
You may need a 1761-NET-AIC to communicate via RS485, as a ton of 1200's (Or all?) didn't support RS485 DF1 out of the box but needed RS232 - 485 conversion.
Welcome to the PLCTalk forum community !
The MicroLogix 1200 has only RS-232 type serial ports, regardless of model or revision. Two other MicroLogix models (the 1100 and 1400) have both RS-232 and RS-485 built into the same connector.
In order to use an RS-485 interface you will need some kind of converter; the 1761-NET-AIC is the standard one from A-B.
I would recommend instead using a USB/RS-232 interface on your Raspberry Pi, and an ordinary 1761-CBL-PM02 cable.
Using the standard 1761-CBL-PM02 cable also eliminates any risk of accidentally connecting to the +24V pin in the serial port, which is there to power accessory devices.
I just checked the contrib-pccc nodes for Node-Red and that only appears to support Ethernet, not a serial connection.
So Step 2 is going to be to be sure that the MicroLogix 1200 supports Modbus RTU Slave and configure and test its serial port.
RS485 is only a physical layer that needs to be used if we have to connect several devices using the Modbus protocol.
From the ML side you need the RS232-RS485 interface, and from the PC side USB-RS485 (or RS232-RS485 if we have a physical RS232 port)
If we have only 2 devices to connect: PC and ML1200, then from the PC side we need a USB-RS232 interface (if we do not have a physical RS232 port) preferably on the proven CH340.
The Master can be ML1200 or PC - it depends what we want to achieve.
Of course, you can use the proprietary Allen Bradley interfaces, but I will pass over their prices in silence.
Hello all, hope your week is going well. I am currently working on debugging a Micro850 with Category number 2080-LC50-24QWB. When I connect...
2,352
Has anybody worked with these IX sensors? I'm trying to use one with a 1769-L32E processor (running version 20) but the PLC won't recognize it...
1,954
Hello, I am trying to connect a Sartorius Combics 3 scale (model CAIS3-U) to an Allen Bradley ControlLogix5661 PLC using an Ethernet connection...
3,449
Hey guys, We recently acquired a station that is controlled by an Allen Bradley PLC and HMI. We want to keep the same system running the way it is...
3,254
We have an upcoming software project that will be coded into a ControlLogix (Allen Bradley) PLC. Some of the data items we would like to send...
5,625
