Issue with CPU318, hardware interrupt and CP343-1 Lean card
uptown47
Feb 2008
Over there, next to those boxes
1,146
Hi all,
I'm trying to fit a CP343-1 Lean card (v3.0 6GK7 343-1CX10-0XE0) on to an existing rack that has a CPU318-2 (6ES7 318-2AJ00-0AB0) in slot 2 and a input interrupt card (6ES7 321-7BH00-0AB0) in slot 4.
Initially I dropped the Lean card into slot 5 but found that the lean card wasn't working. I thought it could be a fault backplane etc so tried swapping the interrupt card and back connectors with spares but to no avail.
I then put the lean card in slot 4 and the interrupt card in slot 5 and the lean card worked. Unfortunately then the machine bombed out on a error to do with it's clock pulse. I think the error is because it isn't getting it's clock pulses quick enough. If I 'inch' the machine slowly it all works fine.
The addresses haven't changed on the interrupt card and I can't see anything that would effect its functionality by being moved into a different slot.
Has anyone got any ideas on what might be happening here? Could the 'lean' card be slowing the backplane comms down so much as to make the interrupt card not work?
Or does the interrupt card *have* to be in slot 4?
Or is there any other reason you can think of why this configuration wouldn't work?
Many thanks
;-) :unsure:
How You use Lean in S7 program?
Have You Connections for it and what is slotaddress "W#16#????" there and in S7-call?
Hi Seppoalanen,
I'm not using the lean card in the program at the moment. Eventually it will be used by a PC to retrieve some DBWs out of the PLC. I've done this on some other PLCs and it has been fine. The only difference with this one is that it's a 318-2 and there's a hardware card.
Thanks ;-)
Hi all smart and knowledgeable people.I have a hmi connected to 2 Plcs via ethernet.These 2 Plcs connected to control 2 systems in one machine...
96
Hello everybody, I have Kinetix 5500 (2198-H040-ERS). I'm having issue with this drive. (I believe it's the drive/Kinetix and need confirmation)...
62
Hi Everyone, I am facing an issue while installing the STUDIO 5000 in my windows 10 PC. During installation I am getting an error that " Error...
182
Hello all. I am trying to communicate to an ASi gateway from my CpLX (L16ER). I am able to ping the gateway and it replies. I configured the...
162
Hello All! I am writing today because I cannot figure this out for the life of me. Another site I am affiliated with keeps having their slc 5/03s...
29
487
