Omron C_1W-ETN21 communication with AB Compact Logix
bagged2drag
Mar 2011
Milwaukee
37
I'm hoping someone with experience here can help. I purchased a piece of equipment from a 3rd party vendor. This piece of equipment was supposed to have EIP to communicate with my CompactLogix controller which this piece of equipment is to be integrated with. When I started configuring the equipment per the documentation I received, I learned that it did not come with an EIP add on card, but instead a C_1W-ETN21 ethernet card. Had it been the actual EIP card, I could have simply installed the EDS and called it a day. So far the equipment builder hasnt been super helpful in coming to a resolution here, so I am looking for ways to use the C_1W-ETN21 instead. Does anyone here have experience communicating with an Omron CP1H using the C_1W-ETN21 and a Compact Logix? I seem to be getting mixed info online whether this can be done using a generic ethernet module or if it needs to be Modbus TCP/IP. When adding the card to logix with the generic ethernet module (with the settings the builder provided to me) it results in an error trying to connect (exclamation mark in the logix tree).
Thanks,
You could possibly use Modbus TCP - Omron have FBs for client/slave.
I was able to secure a cj1w-eip21 EIP card now. I am still trying to work through implementation if anyone has expeirince with this.
Thanks,
Hello everyone, I would like advice on the setup below: CJ2M PLC: 192.168.10.01 (Subnet: 255.255.255.0) ETN21 - 192.168.20.1 (Subnet...
1,859
Dear all, I am trying to realize a configuration in which I place 2 pieces of CJ1W-ETN21 onto my PLC main rack (PLC is CJ2M-CPU33). The 2 pieces...
1,857
Hello all, has anyone configured before 2 CJ1W-ETN21 in a single rack? I am trying to put 2 units of ETN21 couple with my CJ2M-CPU33 to act like...
1,269
Hi all, We've encountered a bit of a puzzling issue with an Omron CJ1M-CPU12 PLC on a site. Basically, it's not letting us write configuration...
5,360
Hi all, I have a customer that has a series of around 15 Omron CJ1M PLC's, each connected to an Omron NS8 HMI via an ETN21 module. The PLC and...
2,911
