I have problems when trying rslinx and micrologix 1500
gemedina31
Nov 2017
Cali
Regards,
I have never had any problems communicating through rslinx with the AB plcs, but I have run into a serious problem, which is that I have not been able to access a Micrologic 1500 using the original 1761 CBL PM02 serial cable. I tested if it is the cable that is bad, but as I say with other PLCs I can access autoconfiguration with DF1.
The problem is that, when doing autoconfig in DF1, it does not detect the PLC. I called the person who programmed the ML1500 and communicated very easily, but I noticed that he did not do it with autoconfiguration as is normally done and I inferred that the man somehow blocked the communication with the controller to not allow access to his program. Is this possible to do?. Can i decipher it? How do I do it?
I await the prompt response of a good Samaritan.
Thank you.
I have been having problems restoring application in FT ME from a runtime (.mer) in the latest version of FT ME (v6.10). The displays have...
30
13,754
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
218
Anyone have problems/solutions with Rehosting Studio 5000 to a new computer. Our IT department successfully Rehosted 2 laptops, but the other 2...
162
Hello. I appreciate the insights here and the willingness to share. I've got a lot of Rockwell experience, but my Siemens experience is...
207
