ATV320 vs ATV312 problems
ganutenator
May 2002
kansas
1,440
As you know, Schneider is phasing out the 312.
We have had problems w/ the 320 following the decel ramp.
Anyone else?
Also, we have had to adjust slip compensation way down to keep the drive from sitting there confused on a direction change during the ramp.
I’ve seen you post something similar to this in the past, I can’t help on your question yet. But may I ask, are you having issues getting 312’s now?
We use a lot of 312 that we had to replace 31’s with. The 312 performed just as well as the 31’s. They were set and forget drives that were extremely well priced. Is the 320 the new “bookshelf” style drive? If so we did do a recent project with them and had no issues, but were uni-directional, except for a manual for a manual jog, with extremely fast cycle time and fairly mild cycle rate.
We had problems getting the 312s, but not now. Customer has enough money to buy in bulk.
I forget the exact date that they are phasing them out, but pretty sure it is by the end of 2018.
The 320s had the Fault problem (forgot actual code), but they finally fixed it w/ a firmware update.
They still suck though (in my opinion).
They come in a similar form factor as the 312 and in a book case type form factor.
Hi , My devices are m241 and atv320 , i did paramaters settings , ı wanna read or write Fr , Current , Voltaga etc. However ı couldn't connection...
2,785
Hello all, I have a Siemens 1200 plc which I am trying to get to communicate with a schnieder atv320 inverter with a profinet card. I have the...
2,148
Hi, I have a Schneider VFD - ATV320, 1.5kW for a Horizontal motion in which when it is running it shows nLP intermittently in between. First DBR...
3,158
I am using soMachine 4.3 with a M241 commanding an ATV320 by EthernetIP. We have the comm working fine, and using the GIATV.Control_ATV function...
6,487
The ATv 31's and 312's worked great. sans so move and the documentation. Why did they have to discontinue them? The 320's are not performing...
1,804
