still having trouble w/ the schneider ATV320
ganutenator
May 2002
kansas
1,440
The ATv 31's and 312's worked great. sans so move and the documentation.
Why did they have to discontinue them?
The 320's are not performing well.
had numerous out of the box INFE faults. supposedly this new firmware addresses that.
had problems w/ the 1/15 motors on the 1/4 hp drives using sensorless flux vector control. switched to the default motor control type, it works.
Now having problems w/ reversing direction at just the wrong time during the ramp decel. the drive sticks at -7.8hz when it is being commanded fwd until it faults on current limit. wtf?
anyone else having problems w/ the atv320?
So far no hardware problems. Just really dont like the numbered menus now. Real pain re-learning all the codes
update
well, obviously the infe faults were a real thing, as they released a firmware update to address specifically that.
Still having intermittent problems were the drive is given a rev cmd at some stage through the drive fwd deceleration which causes it to hang and then eventually fault out.
Thanks for all your great help I really appreciate all of the suggestions and I think I have tried them all. but I still cannot get my rslinx...
2,375
and apparently my r and 0 keys. altivar 320. Calculated stop works near perfect for the ATV 312. ATV 320 not so much...
1,046
So much thanks for your reply.... I have rearranged the RS232 pins as 2-3, 3-2, 5-5 and then I configured driver as RS232 DF1 with 19.2K baudrate...
4,231
i AM HAVING A PROBLEM WITH AN SLC 5 PLC. RS LINX IS ABLE TO FIND BOTH NODES. BUT, WHEN I TRY TO GO ONLINE WITH THE PLC RS LOGIX STOPS SHOWING NODE...
3,622
Why is the configuration IP different from the actual IP address still able to run normally?
833
