still having problems w/ altiva 32s
ganutenator
May 2002
kansas
1,440
and apparently my r and 0 keys.
altivar 320.
Calculated stop works near perfect for the ATV 312.
ATV 320 not so much.
Code:
On-the-Fly Time Delay Calculation (using current velocity)
Time Delay Before Stop = (Desired Stop Dist - (Velocity in ft/sec **2 / 2 * drive decel))/Velocity
(*** BRIDGE ***)
(*convert current bridge speed rpm into ft/sec*)
bridge_write_speed_real := INT_TO_REAL (IN := Bridge_write_speed_rpm);
(*1.5708 x velocity ft/sec / 30 (30:1 gear box) x 60 sec*)
bridge_write_speed_ft_sec:= 1.5708 * bridge_write_speed_real / (30.0 * 60.0);
(*calculate time delay for stop; if/then prevents a divide by zero error*)
If (bridge_write_speed_ft_sec > 0.0) then
	bridge_stop_time_delay_real:= (1.0 - (bridge_write_speed_ft_sec**2)/2.467)/bridge_write_speed_ft_sec;
	(*convert decimal time delay real into milli seconds*)
	bridge_stop_time_delay:=REAL_TO_DINT(bridge_stop_time_delay_real * 1000.0);
end_if;
If (bridge_stop_time_delay > 0) Then
	bridge_stop_time_preset_calc:= DINT_TO_TIME(bridge_stop_time_delay);
else
	bridge_stop_time_preset_calc:= t#0s;
end_if;
i AM HAVING A PROBLEM WITH AN SLC 5 PLC. RS LINX IS ABLE TO FIND BOTH NODES. BUT, WHEN I TRY TO GO ONLINE WITH THE PLC RS LOGIX STOPS SHOWING NODE...
3,622
The ATv 31's and 312's worked great. sans so move and the documentation. Why did they have to discontinue them? The 320's are not performing...
1,805
So much thanks for your reply.... I have rearranged the RS232 pins as 2-3, 3-2, 5-5 and then I configured driver as RS232 DF1 with 19.2K baudrate...
4,231
Thanks for all your great help I really appreciate all of the suggestions and I think I have tried them all. but I still cannot get my rslinx...
2,375
Why is the configuration IP different from the actual IP address still able to run normally?
831
