Connect 2 controllers with EtherNet/IP through a router
You could also check into a NAT device like the A-B 1784-NATR. Use one -NATR per each "private-network" Compactlogix and network the public side of each -NATR to an IP address on the same network as your Omron PLC
^this.
When I mentioned Stratix earlier, I meant -NATR.
42
87
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
105
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
335
What has been your experience with year over year price increases on your Tech-connect service contracts? Is it up to the distributor? 30% seems...
288
