non conductive material inspection - ultrasound, xray, ?
Snap25
Dec 2014
Michigan
237
Could someone suggest any instrumentation to internally view non conductive material? Example : Validate a centered wick in a candle internally.
Looks like a tough application to solve. At first I was thinking of a capacitive proximity sensor and adjust to sense the wick, but you are looking to see if the wick is centered.
Is there other places to sense the product as it is being assembled, instead of the final product?
Seeing if the wick is centered on top and on the bottom could be done with a vision application. But really this is a toughy. Obviously, I don't know any specifics about the application and setup, but I would suggest attempting to make the quality control for the wick placement happen before the wax was added.
An ultrasonic or radar scanner would be able to detect a density change.
I would think the wick would be a different density then the surrounding material
You may have to rotate the part within the scanner to determine if the wick is centered
if we need to take back up of Siemens CPU(s7300 /s7400) with non siemens slave profibus nodes without their gsd files and when we restore it in...
82
Hi all, I have installed a SICK AFM60A-S4IB018x12 encoder to Allen-Bradley CompactLogix PLC and configured its parameters via AOI provided by...
96
Hi, I'm trying to understand a couple of things with a feedback signals that are used in a SRP/CS that I'm working with. Quick disclaimer: I'm...
535
Hello, has anyone ever been caught in this situation? You have redundant CPUs, fieldbus is PROFINET, there are some devices which don't have the...
514
Looking to see if there is any sort of publication or details on if I can tie a 1794 AENT module to a 3rd party eth/ip scanner (happens to be opto...
704
