WonderWare ver 9.0
rick62
Jul 2013
tuscumbia al
45
I keep having this issue when I start the ArchestrA DASABCIP server, sometimes it connects good and then, sometimes I keep getting this error--[connection attempt to to DASABCIP on dell REFUSED, SLSSVC not running, resources out at server ,dup IP # problem. I always check out all of these errors, but can never find out why this happens sometimes- my op system is xp , I use this pc a lot, and sometimes I have no issues at all when I edit any wonderware projects, and sometimes this error is hard to solve, have never found out why this happens sometimes and then goes away-- :cry:
Tell us more about your network. Are you using fixed IP addresses? Is your hosts file properly configured to associate relevant node names to IP addresses?
don't know what you mean by fixed, but example=pc 192.168.0.100 plc at 192.168.0.20 also as of host files, do you mean the windows etc host file ? can you give am example. also I am using SuiteLink protocol-
What version of the DASABCIP server and what PLC are you trying to connect to?
connection to a slc505 and compactogix , DASABCIP 4.0 , I have connected to this configuration before with no issues, buy for some reason I sometimes get this -- WWSLS connection attempt to DASABCIP 0n 192.168.0.25 REFUSED- The last time it took me several days to get it to connect, but I can never figure out why it does thisor what I do to get to work. this is the only problem I have using suitelink server, but sometimes it works good??? slc address is 192.168.0.20, this issue seems to be intermit. all my license is good-
I am trying to add a TCPIP server group to integrate a Schneider M221 PLC in to Wonderware. When right clicking on the Operations Integration...
441
Pretty basic question but I haven't touched WW in many decades. The background is there are some AB PLC data I like to sent to OSI PI Historian...
1,529
Hello, I have Aveva 2020 R2 running on a Windows 10 PC. My issue is that the tags on the HMI do not all update (some do) while logged in as...
1,721
So, a WW PC's hard drive decided to go bunk. The local tech did use Windows 7 Back and Restore to save an image. However, the restored image...
1,023
Good morning guys. I'm posting here because I have a situation that I can't solve.. we are migrating from intouch 10.1 to 17.2 and we install...
1,651
