Hello,
If I have a 5.5 kW electrical 3 phase motor with no load(free axis) and measure the active effect, what value in kW can I expect roughly?
When I test a motor (full voltage) with no load and its current is higher than 25% of full load , my decision is not to buy it.
Why does it matter?
Siemens used to have a motor plant here in Colombia , they closed it years ago.
All motors from that plant used to consumed almost 50% of full load current with no load. No body wanted to buy those motors.
If you are talking about a motor with permanent magnets on the rotor, like a typical servo motor, the current/power draw will be very low with no load. If it's an AC induction motor the magnetizing current can be a considerable value depending on the design/purpose, but most drives typically factor this in and report low power usage despite the higher magnetizing current.
Heh!
Love your signature line.
Originally posted by lfe:
That current does not count in the energy consumption.
