Motor connected to Load on VFD Parameterization
Jieve
Feb 2012
USA
274
Simple question that I keep forgetting the answer to:
When a VFD is running it's motor auto-characterization routine (static and rotating) where it determines motor parameters (resistance, inductance, etc.), should the motor be completely mechanically disconnected from the load, or installed driving the equipment during the process?
Context: Siemens G120 Drive, 3hp Motor, can't seem to find this information in the Siemens VFD manual for some reason.
I don't have any experience with Siemens drives, but on Allen-Bradley drives, typically you do a Static Tune if you can't uncouple the motor from the load, and a Rotate Tune if you are able to uncouple the motor from the load.
Thanks for that response. Looks like Automation Direct has a video for one of their series of VFDs where they say exactly that, so I'd guess that's most likely the case with most brand VFDs.
My habit is P1900 to a 2 (motor ID)
then I do a P1900 to a 3 (speed controller)
I then set up a trace and look at speed and current
for open loop vector I adjust P1470 and 1472 if necessary
Also P96 must be a 2 for this mode
I don't disconnect the motor or gearbox )
I can say I've fully understood that theory
Hi all, I am trying to find a way of detecting a motor is not isolated before attempting to run an inverter. We would normally use a 4 pole...
19
3,082
have a Yaskawa Z1000 125HP drive tripping oC (over current). I have disconnected the motor and every time I power up the drive I get that fault...
5,941
Hello Every Body I Have A Telemecanique Drive For Controlling Speed Of 1.5 Hp Rating Motor. Motor Winding Is Star Connected. After Discussion We...
3,319
Where can I get information on their programming process. I was told by their reps that I cannot up load the program in the m940 to my pc because...
2,257
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
261
