Hello,
I'm running into an issue with how to resolve an indexed data array ADD in a SLC 5/5 to a Compactlogix 1769 L33ER conversion process.
I get a PCE error on the rung as "invalid expression or tag." I vaguely follow what's going on in the SLC. It's sampling a flow every certain seconds and adding to that index. I'm looking for suggestions on an easy way(or any way) to translate this to the compactlogix.
I get that the F (F33 0-256) is the array file of samples. [N7:7]:[N7:6] where 7 is the file index and 6 is the index counter.
Attached are the SLC and Compactlogix rungs top and bottom respectively.
Any ideas from you all out there is really appreciated!
