Old Honeywell Software?
BAJ
Jan 2006
Maple Grove, MN
201
Anybody know what software is needed to connect/debug a Honeywell 9010-016C 9100E Logic Processor Controller? Looks pretty dang old.
I have a customer with a bunch of these which they would like a quote to replace, but would like support in the meantime.
Thanks,
-Brad
That is the OLD Honeywell Series 9000 software....late 1980s to early 1993 or so.
Those were actually "York" plcs (bought by Honeywell), pretty good in their day.
You will need Honeywell S9000 software to program...I think windows 3.1 or 3.3. You will also need "Gateway module" to connect to plc from HW S9000 software...whopping 9600 baud speed.
I assume your customer has this system?
You can also go in the "back door" with 623-60 plc software (DOS only).
Yes that is the gateway..
I used to have a copy of the software....I will have to dig thru my archives....no promises.
What was your customer using these PLCs for, did they have a Scada/HMI system communicating with them?
Hey guys, I am trying to pull the ladder logic out of some ancient Honeywell S9000 PLCs, but I can't find the software anywhere (google search...
4,906
I have one old Ansaldo VFD from 37kW and it have only sign OFF on the display after put it on the 3x400VAC. Is there any idea, how to solve this...
53
88
125
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
158
