s7-200 logic simulated to s7-1200 equvailent hardware configuration in plcsim?
abdq
May 2017
indonesia
Dear all,
Currently I have a task to study our s7-200 hardware configuration retrofitting to s7-1200 hardware.
s7-200 configuration:
  • CPU 224 CN AC/DC/Relay 14 Inputs/10 Relays (214-1BD23-0XB8)
  • EM 235 CN Analog Combination 4 Inputs/1 Output (235-0KD22-0XA8)
  • EM 231 CN EM 231 Analog Input Thermocouple, 4 Inputs (231-7PD22-0XA8)
What I want to do is to upload the logic from s7-200 and converted to s7-1200 equivalent hardware configuration and tested in PLCSIM TIA V13, is it possible to test the converted logic in PLCSIM without having the hardware ?
For example my equivalent configuration would be like this:
  • CPU 1214C AC/DC/Relay (6ES7214-1BG40-0XB0)
  • SM 1234 AI 4 x 13 bit / AQ 2 x 14 bit (6ES7234-4HE32-0XB0)
  • SM 1231 AI 4 x 16 bit TC (6ES7231-5QD32-0XB0)
Thank you
Hello, I was wondering if anyone would be able to help me out; I have a PLC2 file that I can't access (I don't have the software). Would anyone...
802
Hello expert, Kindly help me to open/view the locked block in the attached S7-200 backup "Lim_Switches" Thank You.
628
Hi Experts, I'm new to the S7-200 PLC program. I need to convert the S7-200 program to S7-1200 PLC. What is the conversion for SMB28 and SMB29...
1,601
I have an allen Bradley micro running a fan in an industrial paint mixing facility. The input fuse is 3a. The system will run fine for a bit and...
2,005
Hi we currently have a Micrologic 1200 running an automated saw program. If I plug in a memory module will it automatically write the program to...
1,291
