I use Alarm DB View ActiveX Control and I have two problems with it.
First: In order to refresh the control from the database(SQL Server) I use method Refresh() in the WhileShowing script of the wnd that contains this control. But when the function is performed the control "flashes "("jumps "). Because the Refresh() method is performed every 800 msec the wnd "flashes"("jumps ") all the time. How can I avoid this problem? How can I refresh the Alarm DB View ActiveX Control from the database without this flashing ?
Second: the control gets alarms from a lot of stations. I need to provide an option to show alarms related to specific stations, i.e I need to filter alarms by Station Name(in alarm comment). How can I do it?
Inna
Inna
