1761-CBL-PM02 null modem and gender changer
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,791
Is there a cable that I can buy that is the equivalent of the
1761-CBL-PM02 plus a null modem and gender changer?
I have some new radio modems that work with this but in the field I would prefer not to have the extra adapters if I can help it. I can probably buy a single adapter that does null modem and changes the gender but would prefer to just buy a single cable that does it all.
TIA
Paul
Do you still need the Null Modem side or just the gender changer?
Heading out on a service call.... call me tomorrow AM
I didn't see those their yesterday in that category. I was pretty hopeful about this radio trial yesterday, but have run into issues. Another one whose software is 5 years old, designed for a different model radio and 'doesn't quite work right with this new model, please use the command line interface to set it up ...' I could go on a tangent about how all radio modems are cr*p, each in its own special way....
But if this modem does work for a 24 hour test after I set it up with hyperterminal, I will definitely buy those parts all from you, Mark!
I have plenty in stock if when you ever need them... and congrats on your 10,000 post, thats a lot of people you have helped 🍺
Wow, I hadn't paid much attention to that counter...thanks for pointing it out. I have tried to be helpful, but as much as anything just vocal...I know I have learned enough from this site to make my little contribution a very favorable trade.
The manual for the 1761-NET-AIC shows connecting a PC to DH485 network with a 1761-PM-02 cable. Is this done using a DF1 driver set to...
1,060
So, I need a RS485 Modbus slave to do some testing. Well, since I don't have any RS485 Modbus Slave sitting around but does have a Micrologix...
3,188
Good day, I have a little problem with connected a PLC micro 850 Allen Bradley with a HMI C200. Already connected PLC with ethernet cable in my...
1,406
Hi everyone! I am new to the site, I found it while trying to find help getting my driver set up. I am a Mechatronics student, and we are now...
3,407
hello my frinds I would like to explain to you that we have a small water treatment unit controlled by small logic controller (micro logic 1200...
10,003
