Schneider Advantanys PLC Communitcating
Hoffin1008
May 2017
Swadlincote
Hi all. New to the forum.
I am looking for some information on how to get two PLC's to communicate with each other and get information from one plc to fire a physical output from a separate PLC and plc program located elsewhere.
I have a few override functions on a conveyor hmi that requires a warning light putting in to show if any of them are on. I have found where it is written in the plc and have wrote the code to fire one single output when any of the overrides are on. The only problem I have is the spare output and output card I have is on a different PLC. Not for the conveyor but for robots. Now they talk between each other constantly but how do I write the logic to fire the spare output on the output card on a different PLC Rack?
Any help would be very much appreciated
Thanks in advance
Tom
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
39
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
129
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
61
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
105
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
187
