How To Connect SQL Server database with Vijeo Citect 7.20
Jul 2017
bandung
I have any trouble about connection from SQL Database server with Vijeo Citect version 7.20, I've made a database in Microsoft SQL Server, and I was made query in trigger table, the Query Executed has successfully but if I run the VijeoCitect, Fail command has appear, my cicode query has created with use an IP server database (IP Computer) , But isn't work.
can you tell me how to solve it? thankyou :)
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
133
Hi, Can someone guide me through how to use FactoryTalk SE VB script to open communication with SQL Server? which command I can use? Are there...
2,301
Hi all, I'm trying to connect my WAGO PLC to multiple databases. It is currently connected to a single MySQL database using the library...
922
Hello Everyone I working in power plant and we using citect 7.20 , how we can connect citect to mysql to show some system info on website or...
1,486
Can someone help me because my Adodc is not communicating to my SQL pack? 1 - My factorytalk 8.0 when I fetched the Object - Active Control -...
1,166
