Saturn_Europa1 Member Join Date Mar 2016 Location Raleigh Posts 88 Feb 16, 2017 #1 I had an and block that wasn't anding today. Inputs were true but the output wasn't true. Please see picture. I ended up going into editing, deleted the band and put in a new one and it worked as expected. Very weird.
jkerekes Member Join Date Aug 2007 Location NJ Posts 2,363 Feb 16, 2017 #2 Did you previously use more than two inputs? I've done it where I reduced the number of inputs used , but the block still retains the last value. For an AND, if one of the other unused inputs is a zero, it won' t "AND".
Saturn_Europa1 Member OP Join Date Mar 2016 Location Raleigh Posts 88 Feb 16, 2017 #3 There is a strong possibility that it had three inputs. I modified a bunch of logic and was moving stuff around. Thanks for the reply!
