MicroLogix 1100 and Panel View 300
JBradley
Nov 2005
Russellville
21
Hello,
I have a micrologix 1100 and a panel view 300 micro that i need some assistance with. I can't get the two nodes to match up. They are both node 1. I get communication errors and i am unsure how to change the nodes on either device.
Thank you
JB
It would help if you posted the complete catalog number of your PanelVeiw 300. Also post your ML1100 code (.RSS file) if you can). What port are you using on the ML1100 and how is it setup ( DF1 or DH485)? The more info the help ypu will get.
Good morning, I would have a question to ask you. I have a Micrologix 1100 to which I have to connect a PanelView C300 in ethernet. I have...
2,107
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
163
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
604
I am trying to set up a read message in a MicroLogix1100 to read the value of a DINT in a ControlLogix5561. I have successfully set up a message...
213
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,215
