Siemens TCP/IP Driver to communicate with PROFINET CPU?
natirm
Nov 2007
istanbul
21
I'm trying to communicate Kepware's OPC server with Siemens SIMATIC S7-300 CPU 315-2 PN/DP. But i get the following error on Kepware : "Siemens TCP/IP Ethernet Unable to read 2 bytes starting at offset 0 for Data Block DB200 (e.g. DB200,DBX0) on device 'Channel1.Device1'. Device returned data access error
Code:
I used Kepware to communicate with S7-300 with additional ethernet module before without any problem. But i guess the reason i cant communicate now is this CPU uses Profinet????
I read somewhere on internet profinet can response normal tcp/ip requests. I know very little about Siemens PLCs, anyone got any idea about what might be the problem ?
Thank you!
I need to know the steps to communicate Citect 2016 with Siemens S7 1500 using S7TCP driver. Thanks
27
17,883
Hi, Can anyone please explain how to setup fix 32 6.15 to communicate to a s5 plc. I have copied exactly what was defined in an Intouch...
6,348
I am trying to establish communication between Siemens PLC 1500 and Matlab. I followed a tutorial on youtube at this link: But when I got to the...
352
Hi, If we have PLCs on different subnets is it possible to do TCP comms data transfer between them? I'm assuming if we use a routing switch and...
821
Hello All, For S7-400H system, can we make this redundant PLC (connected to one uplink switch) to communicate simultaneously with 3rd party HMI...
1,465
