KyHx
I have two Vlans set up for two differnt control sections,(vlan id 1001 and 1003) they are also in two differnt subnets (10.100.1.xxx and 10.100.3.xxx masked 255.255.255.0).
I need to pass a SLC 500 write message from one control section to the other. Everything is Layer 2 Switches. Will a router or layer 3 switch fix allow me to do this? Does the router need to have two WAN ports?
Along with this question is it possible to bring the two vlans to one NIC card so that i don't have to switch ports on my switch to make programing changes to the separate control sections. I also want some factory talk screens to monitor the two sections.
