Using RSlogix 5000 Emulate with Compac Logix program
saldios
Jan 2006
Waterford, MI
I have an existing Compac Logix program and I would like to run it using the RSlogix 5000 Emulator. is it Possible can some bocy give me directions?
Yes its possible. But unfortunately when you emulate a CompactLogix, it converts it to an emulated ControlLogix. What this means is that you have to delete your CompactLogix I/O from the project.
Jkerekes,
does it means I need to create all my tags but now in the Control logix platform right?.
I sow that, and I was trying to find a way to get around it.
thanks a lot any way.
but I have seen in this forums a different answer from another member to the same question (not my inquiry) made from somebody else.
the answer says as follows: I just tuck a compaq logix program from a machine that is running and just change the processor to the emulator and it runs just fine. I don't understand how he could do that.
Basically you need to change your CPU type to a Emulate 5000 Series Controller
Go to your controller properties for this.
Make sure you note your Slot Number and Revision (Slot Numbe is virtual). When I do this; I normally save this project with a different name and keep my original project intact elsewhere.
Once you now have an emulate 5000 controller- check you can compile your project- you may have to delete certain other IO Modules (and all affected tags) to get a compile.
Once complete you need to set up your emulator, so open 5000 Emulate from the start menu and set up your virtual chasis, make sure the CPU slot and revision match exactly to your controller.
Next- leave your emulator open and open RSLinx Classic. Here you need a new driver via the 'virtual chasis', once created you should be able to open your virtual chasis tree.
From your RSLogix/Studio5000 Project you can now navigate to the controller via RSWho, download your project and you should be good to go, the real life hardware switches (run, remote and prog for example) are controlled directly via the emulate
If you want this program converted- please feel free to upload and I will change it for you.
Regards
Daniel
Hi, I'm just looking for a simple way to make a button in excel (via VBA I presume) to toggle a bit in RSLogix 5000. I just got FactoyTalkLinx...
583
Hi All, I'm working on an AOI that needs a ONS incorporated into the logic. Every time I run the instruction the ONS gets stuck on even when the...
3,257
Hello, I please need your help why I cannot get the return parameter from the RET instruction to go into the return parameter in the JSR return...
2,866
Im running windows 7 on vm and studio 5000 is version 27. I opened a clients file this morning to add expansion i/o and drives and as i was adding...
1,443
Hello PLCS.net! Here again to ask about how to do some weird quirky thing with RSLogix 5000. I see my team trending a lot of tags, but it becomes...
1,562
