Pilz plc unit showing ofault
Saudi jamal
Jun 2015
oman
147
Hi guys,
i am facing problem on pilz (type pnozm1p.this problem is ofault led is continue flashing.we made several time power reset but still same. We removed output cable and make it reset but still same fault.
Kindly if any one have any idea about this pilz safety plc unit kindly help me to solve the issue.
Kind regards.
Jamal.
Just before replacing the unit...
Check the feedback circuits. If the feedback circuit is not working correctly (if it is OPEN with the safety output OFF) you will get the OFAULT LED on.
These units are very easy to go online with, the software is free i believe? This is the easiest way to diagnose the fault.
If you do end up replacing the unit make sure you remove the sim card from the top as this contains the program.
Dear All. I need comm between Compactlogix/Controllogix with PNOZ m1p ETH. What we need the communication option? or can be connect direct? many...
1,179
Hi, Dear friends. in my PILZ PLC PNOZ m1p FAULT indicator is ON, PLC not running, i downloaded demo software from PILZ website. it has one D...
6,365
Hi All, I'm currently working on a project where I have to set up ethernet comms with a Pilz PNOZ Multi M1P Eth from AB L72 PLC. I have it...
5,044
hello all i've a machine controlled by a PILZ plc (pnozm1p), i left this machine for 6 month without powering up. now,when i try to run it, the...
2,175
Hello Experts, I have two Pilz PLCs supplied by vendor on our site. Customer wants to communicate these Pilz PLCs with our ControlLogix PLC on...
6,361
