AB KT type communication
plcisgreat
Guest
P
Does A-B have a communications cable that can be used with all the processors?
Simple answer is NO...AB uses different connectors...ie RS232 which is normally 9 pin serial but may also be a mini din. DH485 (a form of RS485) may use a 4 wire connector or an RJ connector. Ethernet is also done thru an RJ connector.
Closest you can get is to use a laptop with a 1784-PCMK/B and the variety of cables needed to connect to all but Ethernet...that can be done with a regular net card and cat 5 cable.
AB covers a lot of different devices,Panelview's use a variety of cables too. THE above was for the PLC's.
Hello all, I have been implementing a CAN based communication protocol. During reading the documentation I have found that there are several data...
1,767
Dear all, I tried to download program on a S7-300 PLC (CPU 315-2PN/DP)that is not done. But the same program I tried on the same other PLC CPU...
16
5,588
Hey guys, I just wanted to see if any of the bright minds on here had any opinions on these relay interface modules. Particularly, I would love to...
44
82
282
