Siemens S5
chainsaw2272
Jan 2014
joliet
I am looking at some S5 statement list programming involving an extended flag. I can't find the difference from a flag and a extended flag. Any help or a direction to find the answer would be helpful.
Thanks Mike
"Flags" usually means the "Merker" bits Mx.y.
Maybe you mean the extended datablocks, DX ?
These are like normal DBs. As far as I remember it is for when the normal number of DBs supported by a CPU is not enough.
Disclaimer: It is 20+ years since I had to work with S5 :)
If you mean S-flags, their use is restricted compared to M-flags.
As far as I can remember, the S-flags cannot be used as parameters on FB-calls (the bit length of the MC5-code does not 'fit').
I'll look for the manual ...
Kalle
115
134
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
293
i have two plc 1. s7-1212dc/dc/dc ip; 192.168.0.1 2. s7-1500 1513-1pn ip; 192.168.3.2 i need to get data from plc1 to plc2. any idea how to do...
109
Hi everyone hope you'll well. Is it possible for me to download a Crack version of tia portal v13..sorry to say this but the software is very...
198
